[Qgis-developer] WG: Re: couldn't load cpp-plugin
SSchmidt at gfi-gis.de
Tue May 6 06:53:19 PDT 2014
I've made some progress:
In my working plugin I placed this two lines:
QLibrary myLib( "C:/Progra~2/QGISVA~1/apps/qgis/plugins/tb4qgisplugin.dll"
bool loaded = myLib.load();
and get this messages:
"qgis-bin.exe": "C:\Program Files (x86)\QGIS
Valmiera\apps\qgis\plugins\tb4qgisplugin.dll" geladen, Symbole wurden
geladen.
Eine Ausnahme (erste Chance) bei 0x77c81d82 in qgis-bin.exe: 0xC0000139:
Entry Point Not Found.
Valmiera\apps\qgis\plugins\tb4qgisplugin.dll" entladen.
But which is the entry point of my dll?
is it the run() of my plugin? I didn't changed the code, what could have
happened?
Sent by: qgis-developer-bounces at lists.osgeo.org
06.05.2014 11:49
To
qgis-developer at lists.osgeo.org
cc
Subject
[Qgis-developer] couldn't load cpp-plugin
Hello,
I know, its a worst with the c++-plugin-developers...
Again I have a problem with a plugin in updating.
In QGIS 2.0 (32bit) I have two plugins working. Now I downloaded the
sources for QGIS 2.2, compiled it and was very happy, because i've had no
problems here. I compiled my two plugins and get also no errors. The first
plugin works fine in QGIS 2.2 (32 bit) but the other gets an error
(written i protocol-extensions) while starting QGIS and loading the
plugins. But the errormessage is not so meaningful : "The procedure is
unknown", but which is meant? Besides I could not debug this. Until now i
debugged my projects when qgis has been started by detaching the process
in Visual Studio. How can I get the Name of the procedure? I think I'm
searching the needle in a haystack.
Has anyone an Idea?
Thanks a lot.
SSchmidt_______________________________________________
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140506/8aee5af2/attachment.html>
