[Qgis-developer] Fwd: [gdal-dev] Call for discussion on RFC 46: GDAL/OGR unification
Even Rouault even.rouault at mines-paris.org
Thu May 8 01:38:19 PDT 2014
Le jeudi 08 mai 2014 07:56:23, Paolo Cavallini a écrit :
> Il 08/05/2014 00:28, Even Rouault ha scritto:
> > This might be of interest for the OGR provider in QGIS.
> > ----------  Message transmis  ----------
> > Sujet : [gdal-dev] Call for discussion on RFC 46: GDAL/OGR unification
> > Date : jeudi 08 mai 2014, 00:13:22
> > De : Even Rouault <even.rouault at mines-paris.org>
> > À : gdal-dev at lists.osgeo.org
> > Hi,
> > This is a call for discussion on "RFC 46: GDAL/OGR unification"
> >   http://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification
> Merci Evan, very interesting indeed. I guess this will imply a significant
> amount of work from the QGIS side.
It depends on how much you want to use the new capababilities. A first step
would be to remove all the metadata about OGR drivers that have been added to
the QGIS code base (extensions, creation options) to use the equivalent new
metadata capabilities of OGR drivers, that would also include open options.
A further step would be to handle mixed raster&vector data containers as a
single dataset.
> This could be the right time to do the
> final cleanup we have been talking about several times, removing all the
> different "Add..." buttons, and unifying the interface (perhaps using only
> the Browser).
> All the best.
Geospatial professional services
http://even.rouault.free.fr/services.html
