[Qgis-developer] Fwd: Bug fix and tests
Gino Pirelli luipir at gmail.com
Fri May 9 02:38:17 PDT 2014
I'm starting to approach a bug fix about a blocker (for me) bug (
https://hub.qgis.org/issues/10216)... I compiled tests to check if my
modification could break something
naturally I checked test before my patch and I find
80% tests passed, 18 tests failed out of 92
Total Test time (real) = 271.32 sec
The following tests FAILED:
  4 - qgis_diagramtest (Failed)
  5 - qgis_diagramexpressiontest (Failed)
 16 - qgis_maprenderertest (Failed)
 27 - qgis_composermaptest (Failed)
 30 - qgis_composerrotationtest (Failed)
 32 - qgis_atlascompositiontest (Failed)
 36 - qgis_composerhtmltest (Failed)
 38 - qgis_composerscalebartest (Failed)
 43 - qgis_shapebursttest (Failed)
 56 - PyQgsLocalServer (Failed)
 73 - PyQgsComposerHtml (Failed)
 76 - PyQgsComposerMap (Failed)
 81 - PyQgsAtlasComposition (Failed)
 85 - PyQgsPalLabelingCanvas (Failed)
 86 - PyQgsPalLabelingComposer (Failed)
 87 - PyQgsPalLabelingServer (Failed)
 89 - PyQgsSpatialiteProvider (Failed)
 91 - PyQgsAppStartup (Failed)
most of them related to composer so probably will not be affected by my
rovider patch
this mail only to suggest to maintain tests too otherwise patching will be
more difficult
thank you, Luigi Pirelli
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140509/04856fb8/attachment.html>
