[Qgis-developer] [Qgis-user] Text size expression
kimaidou kimaidou at gmail.com
Tue May 13 02:19:15 PDT 2014
Hi Andrea,
I did not mean to use CSS files, just be able to use the style property of
HTML tags, such as :
<span style="font-weight:bold;color:blue;">[% "column_a" %]</span>
like we are already able to do in the "Display" tab of the vector layer
properties dialog. This way we could use HTML syntax to style labels. It
won't be easy to implement though because it will overlap features proposed
by expressions for the label configuration options.
NB: I added qgis-dev to the list for gathering feedbacks on this.
Michael
2014-05-13 9:21 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> I like the label in html, but
> I fear of a worst effect.
> The increasing of the files to distribute with the datasets and the
> project.
> Actually we should send SVG and the path to set, the shapefiles, the qgis
> project.
> Also many css files in specifics paths ?
> ugh !
> 2014-05-13 8:32 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi all
>> What about having the capability to display labels in HTML ? Exactly like
>> tooltips , this would let the user create an expression to create a text
>> with CSS styling. Would this be feasible, and no performance killer ?
>> Michael
>> 2014-05-13 7:38 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Il 13/05/2014 04:38, Larry Shaffer ha scritto:
>>> > Hi Liam,
>>> > Having multiple font sizes per label is not supported yet.
>>> Hi Liam,
>>> could you please open a ticket requesting this feature?
>>> Of course, any support you may give will make it happen faster.
>>> All the best.
>>> Paolo Cavallini - www.faunalia.eu
>>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140513/bcaacc50/attachment.html>
