[Qgis-developer] python: no module name core
Alexander Bruy
alexander.bruy at gmail.com
Tue May 20 09:21:29 PDT 2014
I also have troubles with Python plugins and bindings. For example build failed
with error
[ 6%] Generating ui_frmVectorGrid.py
An unexpected error occurred.
Check that you are using the latest version of PyQt and send an error report to
support at riverbankcomputing.com, including the following information:
* your version of PyQt (4.9.1)
* the UI file that caused this error
* the debug output of pyuic4 (use the -d flag when calling pyuic4)
make[2]: *** [python/plugins/fTools/tools/ui_frmVectorGrid.py] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [python/plugins/fTools/tools/ui_frmRandom.py] Error 1
make[1]: *** [python/plugins/fTools/tools/CMakeFiles/fTools-tools-stageinstall.dir/all]
Error 2
make[1]: *** Waiting for unfinished jobs....
This is strange, as my system has Qt 4.8.2 not 4.9.1 Cleant rebuild
and install doesn't
helps.
2014-05-20 17:42 GMT+03:00 Nathan Woodrow <madmanwoo at gmail.com>:
> This seems to be due to my changes today, although I'm not sure what is
> going on unless I stuffed up the cmake files.
> qgis.core is now a package i.e folder and it imports the sip modules, now
> called _core, _gui, etc.
> For some reason the package is missing the core, gui, package folders.
> - Nathan
> On Wed, May 21, 2014 at 12:34 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> it works fine here
>> It might be that you have a plugin that has a package called qgis, which
>> might be shadowing the core one.
>> 2014-05-20 16:27 GMT+02:00 Denis Rouzaud <denis.rouzaud at gmail.com>:
>>> Hi all,
>>> From python console, running from qgis.core import * gives:
>>> Traceback (most recent call last):
>>> File "<stdin>", line 1, in <module>
>>> File "/usr/lib/python2.7/dist-packages/qgis/__init__.py", line 36, in
>>> <module>
>>> from qgis.core import QgsFeature, QgsGeometry
>>> ImportError: No module named core
>>> Any idea what's going on?
>>> Cheers,
>>> Denis
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
