[Qgis-developer] Questing about PAL modifications
Jürgen E. Fischer jef at norbit.de
Wed May 21 06:58:22 PDT 2014
Hi Hannes,
On Wed, 21. May 2014 at 05:29:13 -0700, jmd wrote:
> I started to port the PAL library to Java. I found that a few improvements
> and fixes were made to the source within QGIS but werent backported to the
> library[1]. As the original library is available under LGPL I wanted to ask
> for your permission to make your modifications available under LGPL as well.
> >From the gitlog[2] I found that contributions were made by:
> jef (Juergen E. Fischer)
If you can find any - feel free to use any pal improvements and fixes I did
under LGPL.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
