[Qgis-developer] 2.6: first overview
Niccolò Marchi sciurusurbanus at hotmail.it
Mon Nov 3 01:50:31 PST 2014
ok giovanni, once I understand which plugin is causing the crash, what shall I do? report it?
btw: crashes appeared also while working, even on already-saved-2.6-version projects.
thank you all for the support!
PS
suggestions for the next step? trying to install from osgeo or better to go back to 2.2? further installation of 2.6 didn't help with crashes.
> Date: Mon, 3 Nov 2014 08:39:54 +0000
> Subject: Re: 2.6: first overview
> From: giovanni.manghi at faunalia.pt
> To: qgis-developer at lists.osgeo.org; sciurusurbanus at hotmail.it
> > Crash:
> >         different types. Usually closing the project, QGIS ends up with a
> >         minidump or the MS error window "The software stopped to work
> >         etc etc". This happens closing .qgs from 2.2 with or without
> >         saving to 2.6 version. Sometimes also while working. Attached you
> >         can find the .dmp (shall I upload them? I don't know how to deal
> >         with). Actually it's a quite annoying issue...
> I have seen the crash on exit on several machines, it is usually a
> plugon problem, try disable/remove your plugins, at some point you
> will probably find the one is causing the crash.
> cheers
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141103/cbef7292/attachment.html>
