[Qgis-developer] Trouble with PostGis
Hugo Mercier hugo.mercier at oslandia.com
Wed Nov 5 00:16:37 PST 2014
Le 04/11/2014 21:27, walter.nordmann a écrit :
> Sandro Santilli-2 wrote
>> You'll need to show the query and the definition of the tables
>> involved in it (EXPLAIN
>> <query>
>>  output also helps).
> that is exactly what i did. you can see the query and the explain-output one
> post before.
> and here ist the table definition:
I don't know exactly why, but the code you inserted in your messages are
not visible. They are only visible when using the web-based archives
like nabble ...
So apparently you have filters on geometries (with intersection test &&)
but no spatial index on these geometries.
Something like CREATE INDEX ON table USING GIST(way) could help
