[Qgis-developer] Lizmap web client print tool
Roy royroge at outlook.com
Fri Nov 7 07:28:00 PST 2014
Dear Renè-Luc,
thank you very much for your help,
i can confirm you that with the first test the "Print Tool" is working
on your release_2_10,
best regards,
Roy.
Il 07/11/2014 16.02, René-Luc Dhont ha scritto:
> Hi Roy,
> I take a look at the commit list in lizmap-web-client release 2.10 and
> we fixed this bug after the release.
> https://github.com/3liz/lizmap-web-client/commits/release_2_10
> We need to publish a bugfix release just for QGIS 2.6. The issue is
> due to the new way to define overview in the QGIS Project XML.
> You can download an intermediate here :
> https://github.com/3liz/lizmap-web-client/archive/release_2_10.zip
> Regards,
> René-Luc D'Hont
> 3Liz
> Le 07/11/2014 15:27, Roy a écrit :
>> Ddear Renè-Luc,
>> thanks for you answer
>> Il 07/11/2014 12.30, René-Luc Dhont ha scritto:
>>> Hi Roy,
>>> The documentation is not fully in english but the documentation
>>> exists in French.
>>> The page about configuring print is here :
>>> http://docs.3liz.com/fr/publisher_guide/advanced_lizmap_config.html#configurer-l-impression
>>> Do you have activated Print capabilities for the map in lizmap plugin ?
>> Yes indeed, in the "Map" tab of the Lizmap plugin i activated the
>> "Simple print" option
>> from the docs you pointed (i don't know french sadly) but with Google
>> Translate i understand that
>> only the map element is mandatory and other elements can be set up as
>> north arrow and legend etc..;
>> the template i'm testing only has a map element in A4 landscape page
>> in the apache log i get
>> [Thu Nov 06 16:25:37 2014] [error] [client 127.0.0.1] Warning 1:
>> Unable to find driver JP2ECW to unload from GDAL_SKIP environment
>> variable.
>> Unable to find driver ECW to unload from GDAL_SKIP environment variable.
>> but print in the "Lizmap Demo" works so maybe not related...
>> thanks again,
>> Roy
>>> Regards,
>>> René-Luc D'Hont
>>> 3Liz
>>> Le 07/11/2014 12:17, Roy a écrit :
>>>> Il 07/11/2014 11.54, Andreas Neumann ha scritto:
>>>>> hm - I can't tell you exactly what the problem is.
>>>>> BUT: you cannot mix versions. If your server runs on QGIS 2.6,
>>>>> your client where you prepare the project also needs to be of the
>>>>> same version 2.6. Those different versions are not necessarily
>>>>> compatible.
>>>> Dear Andreas,
>>>> thanks for your replay,
>>>> actually i inverted 0 and 6 in my previous email sorry for the mess !
>>>> i'm using QGIS 2.6.0 both in client (Desktop) and server side.
>>>> Also i wonder if using QGIS desktop on Windows, to setup the project
>>>> and the composer template, is "safe" considering that the server is
>>>> Ubuntu/Linux...
>>>> anyway i'm not able to get the print tool to work preparing the
>>>> project and template
>>>> in Windows, nor in Linux ...
>>>> thanks again,
>>>> Roy.
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
