[Qgis-developer] MetaSearch problem
Tom Kralidis tomkralidis at gmail.com
Fri Nov 14 09:57:59 PST 2014
Hi Paolo: I think this is due to the issue per
https://github.com/geopython/MetaSearch/issues/68 Solution and
workarounds discussed there. This has since been fixed in OWSLib
(0.8.10), MetaSearch (0.3.2) and QGIS master and 2.6 branch.
Are there any plans for a 2.6.1 release? Otherwise this would show up in 2.8.
On Sat, Nov 8, 2014 at 2:48 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 08/11/2014 01:19, Tom Kralidis ha scritto:
>> Hi Paulo: I can't reproduce the error against the RNDT and
>> Geoportale CSW endpoints using 2.6.  Which version of
>> QGIS/MetaSearch are you working off?  It looks like MetaSearch is
>> being loaded from a local plugin install.
> Hi Tom,
> I had 0.3.2. Uninstalled, stock 0.3.1 appears > Errror > No module
> named maindialog; updated, back to 0.3.2 > Error:
> Traceback (most recent call last):
>   File
> "/home/paolo/.qgis2/python/plugins/MetaSearch/dialogs/maindialog.py",
> line 421, in search
>     self.timeout = self.spnTimeout.value()
> AttributeError: 'MetaSearchDialog' object has no attribute 'spnTimeout'
> Then started a clean --configpath (thus 0.3.1, oddly enough no error);
> when searching I got various errors:
> * Data.gov CSW
> Errore di connessione: timed out
> * Geonorge
> Errore di connessione: Opening and ending tag mismatch: link line 6
> and head, line 57, column 9
> * Nationaal Georegister
> Errore di connessione: HTTP Error 401: Unauthorized
> * Geoportale nazionale
>   File
> "/usr/share/qgis/python/plugins/MetaSearch/dialogs/maindialog.py",
> line 467, in search
>     self.display_results()
>   File
> line 479, in display_results
>     's'[self.catalog.results['matches'] == 1:])
> TypeError: %d format: a number is required, not str
> Basically I cannot get anything.
> Thanks.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1
> iEYEARECAAYFAlRdyt8ACgkQ/NedwLUzIr7T4QCgl2v2WzzTkdRtkTOfiWssYsEE
> tfcAnRuglOsl889fSZNrPVkM3iqI26ca
> =9BAG
> -----END PGP SIGNATURE-----
