[Qgis-developer] optionpath su qgis-derver: issues?
Andrea Peri aperi2007 at gmail.com
Sat Nov 29 06:47:55 PST 2014
this work for me:
(using qgis 2.6:)
I put (in the profile file)
this setting:
export QT_PLUGIN_PATH=/usr/lib/x86_64-linux-gnu/qt4/plugins
export QGIS_OPTIONS_PATH=/home/archivio/server/qgis-settings/config/
In the folder:
I put a subfolder named "QGIS"
and inside it I put a file QGIS2.ini   (without any dot in front)
Inside the QGIS2.ini
I put this settings:
[svg]
searchPathsForSVG=/home/archivio/server/qgis-settings/svg/simbologie_continuum_geologia_regione_toscana|/home/archivio/server/qgis-settings/svg/simboli_rt_dbt2k_v0
It work correctly and the svg are shown.
Please notiche the path
is owned from the same user of web server.
regards,
A.
2014-11-29 12:59 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> I noticed that if I set:
>   SetEnv QGIS_OPTIONS_PATH "/.qgis2/"
> www-data writes in it:
>   cache  gdal_pam  qgis.db
> whereas if I set it to a different name, nothing is written.
> Furthermore, a QGIS/QGIS2.ini file does not seem to be used (read/write), e.g. for:
>   [svg]
>   searchPathsForSVG=/path/to/svg
> Has the behaviour of otionspath changed, or am I missing something?
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
Andrea Peri
qwerty àèìòù
