[Qgis-developer] missing qscimod4.sip is stille there
G. Allegri giohappy at gmail.com
Tue Oct 7 01:28:06 PDT 2014
If I'm not wrong you're searching only in your home folder...
That file is required by gui.sip, as you can see. If it cannot be found the
compiler shows the error (the build works fine the second time you launch
it but then you get the Python error on QGIS startup).
The only solution for me was unsetting QSCI_SIP_DIR to disable this sip
part.
2014-10-07 10:20 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch>:
>  The only thing I find is:
> stefan at antigua:/$ sudo find . -iname "*.sip" | xargs grep qscimod
> ./home/stefan/Develop/src/qgis_master/python/gui/gui.sip:%Import
> Qsci/qscimod4.sip
> I’m on a fresh installed 14.04.
> Regards
> Stefan
> *Von:* G. Allegri [mailto:giohappy at gmail.com]
> *Gesendet:* Dienstag, 7. Oktober 2014 10:12
> *An:* Ziegler Stefan
> *Cc:* qgis-developer
> *Betreff:* Re: [Qgis-developer] missing qscimod4.sip is stille there
> Can you find that file on your machine? I can't....
> Where should it be located?
> I fear there was some problem with packages upgrading, but I can't find
> out where.
> giovanni
> 2014-10-07 10:01 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch>:
> Strange, I’m able to compile master with python bindings on Ubuntu 14.04.
> Regards
> Stefan
> *Von:* qgis-developer-bounces at lists.osgeo.org [mailto:
> qgis-developer-bounces at lists.osgeo.org] *Im Auftrag von *G. Allegri
> *Gesendet:* Dienstag, 7. Oktober 2014 09:54
> *An:* qgis-developer
> *Betreff:* [Qgis-developer] missing qscimod4.sip is stille there
> The problem with missing qscimod4.sip from some Debian/Ubuntu packages
> seems to be still an issue. Recently I upgraded to Ubuntu 14.04 and I
> cannot sompile the sip parts of Python yet.
> Nathan suggested [1] to disable the sip parts related to the code editors
> for the moment, but it seems it hasn't been done. Have you found different
> solutions to the problem?
> Giovanni
> [1] http://lists.osgeo.org/pipermail/qgis-developer/2014-July/033928.html
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Giovanni Allegri
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141007/f2963814/attachment.html>
