[Qgis-developer] What does mean "empty tables" in "attribute table" item properties in a print composer?
Junior Delaz delazj at gmail.com
Sat Oct 11 09:27:24 PDT 2014
Indeed, this a desirable behavior: user may want to show empty rows when
there are not enough matching features. This is what I was looking for when
using this option. But having this one working for a table and none among
the three other options is a bit confusing for the user. I spent at least
an hour on testing why these options didn't work and I'm afraid I won't be
the last.
Don't you think that "draw empty rows" can be a separate option (may be a
checkbox)? It'll have its effects on every frame with too higher rows for
the features.
The other three options in the combobox will work only when there is no row
(on real empty tables).
2014-10-09 13:28 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 9 October 2014 08:53, Junior Delaz <delazj at gmail.com> wrote:
> > Thanks Nyall. This is what I suspected.
> > Then, none of the "empty tables" options should work on the frames in the
> > example above, right?
> > But actually, "Draw empty cells" option does have effect on them. Isn't
> it a
> > bug?
> Well - possibly it's a little inconsistent, but I think this behaviour
> is desirable. If you're wanting to show empty cells, I think you'd
> also want to show them when the table is partially filled, rather than
> only when it's totally empty.
> Nyall
> > 2014-10-08 22:33 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> >> On 08/10/2014 10:20 pm, "Junior Delaz" <delazj at gmail.com> wrote:
> >> > Hi all,
> >> > I try to understand the use case of empty tables in print composer and
> >> > am still confused.
> >> > Create a new print composer and add an attribute table item
> >> > set its height enough to show more rows than the maximal values of
> >> > features you set.
> >> > Add a second frame to this item.
> >> > Is this second frame considered as "empty table" (as no feature
> >> > attribute will be displayed inside)?
> >> No. This behavior only triggers when the entire table is empty. It is
> >> designed for atlas prints, where the table's contents are being
> filtered by
> >> the atlas. In this scenario it's possible that no records match the
> filter
> >> for a particular atlas feature and you need to handle empty tables.
> >> Nyall
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141011/c159f4c4/attachment.html>
