[Qgis-developer] Virtual Fields - Allow adding fields out of edit mode
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Oct 14 01:10:14 PDT 2014
Hi Matthias,
Am 14.10.2014 09:56, schrieb Matthias Kuhn:
> Hi Bernhard
>>>> - shouldn't "create virtual field" be the default when layer is not in
>>>> edit mode?
>>> I think it's more predictable (and therefore increases usability) for
>>> users if it's either always on or always off by default. Don't you
>>> think?
>> Ok, agreed, so I opt for "always on" because it will always work
> It should be "always on" for providers that do not allow to add
> attributes.
But thus the behaviour is not predictable either (from a user's point of
view, who is just loading data into his/her project). Virtual field will
_always_ work, no matter which provider.
For others both options always work and I prefer to keep the
> previous behavior (without broad agreement that this should be changed,
> if you convince some people I may change my mind ;-) ).
Anybody has an opinion on this?
Bernhard
>>>> - could the check box "create virtual field" be placed to the right of
>>>> "create a new field"?
>>> "Create a new field" is a group box.
>>> Would you create another group box with all field type widgets?
>> No of course not :-) I was not aware of the group box. I just had the
>> impression it should be there, so moving it on top seems adequate.
> Done!
> Cheers
> Matthias
__________ Information from ESET Mail Security, version of virus signature database 10558 (20141014) __________
The message was checked by ESET Mail Security.
http://www.eset.com
