[Qgis-developer] Create grid in Processing: problems
Paolo Cavallini cavallini at faunalia.it
Thu Oct 23 08:15:58 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all.
I noticed the following problem:
* starting it with defalut parameters in a 4326 project for rectangles
(line) results in;
Algorithm Create grid starting...
global name 'feature' is not defined Vedi il log per maggiori informazioni
for hexagons:
global name 'xVertexLo' is not defined Vedi il log per maggiori
informazioni
whereas for Rectangles (polygon) and diamonds it runs fine.
* the method for selecting the extent is quite unpractical, if
compared to the Vector command equivalent: would it be possible to
change it?
Also, adding the possibility to select the extent by hand with the
mouse on the canvas would be good
* in any case, it seems that the command adds one less row than
expected on the North.
If anyone confirms, I can open the relevant tickets.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iEYEARECAAYFAlRJG60ACgkQ/NedwLUzIr7e6QCeKrrN+XqNDxauy5M8ArwLNJSn
MYsAnAhr2Wtg6dIB2C8Obh9psl6mX4bF
=Khxi
-----END PGP SIGNATURE-----
