[Qgis-developer] Legend-tree: Category checkboxes behave strange on Linux/KDE
Andreas Neumann a.neumann at carto.net
Thu Oct 23 23:28:29 PDT 2014
Hi Martin,
Thank you very much for this fix. So the problem was actually
copy/pasting the rules, and not the legend tree itself. After a new
copy/paste of my rules the problem is indeed gone.
I would assume that this a common workflow. I am most likely not the
only who copies existing rules and paste them for some changes -
especially since the context menu offers this option. I am glad this is
fixed now.
Many thanks,
Andreas
On 24.10.2014 07:31, Martin Dobias wrote:
> Hi Andreas
> This should be fixed in 8db77f. Let me note that the problem may
> happen only with rule-based renderer where some rules have been copied
> (to create new rules) while using qgis master. It should not be
> linux/kde specific.
> Projects where this problem appears need to be fixed by the user - the
> easiest way is to select all rules, copy&paste them and remove the
> previous rules. This will rewrite their non-unique identifiers to
> unique.
> Cheers
> Martin
> On Thu, Oct 23, 2014 at 8:28 PM, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> Is there someone who tests QGIS master on Linux/KDE?
>> I have issues with the new legend tree and the "pseudo-layers" (category
>> checkboxes). Normally a checkbox needs a mouse-click in order to toggle. In
>> the legend-tree on Linux/KDE it seems like if I check one checkbox with the
>> click and then mouse-over other checkboxes, the checkbox-statechange already
>> happens on mouseover. This is very suboptimal.
>> Apparently only the checkbox state is toggled, but not the action associated
>> with the checkbox - thus the legend-tree gets out of sync ...
>> I wonder if others have the same issue? Testing on Kubuntu 14.04 / KDE
>> desktop.
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
