[Qgis-developer] Vector equivalent of a VRT
Even Rouault even.rouault at spatialys.com
Sun Oct 26 07:22:30 PDT 2014
> I still get no syntax errors on opening the VRT, and no features either.
> Could it be the 'slashes' in the filename?
No that's OK
> I would have thought they'd
> be OK because they are in double-quotes:
You likely need to add the attribute  relativeToVRT="1" in <SrcDataSource> so
that the paths are interpreated relatively to the VRT file.
i.e.
 <SrcDataSource
relativeToVRT="1">2730/2730_RIVER_LINE_2006_06.shp</SrcDataSource>
You can check with "ogrinfo -al /path/to/your.vrt" to see if it works and if
there are error messages.
> <OGRVRTDataSource>
>    <OGRVRTUnionLayer name="Rivers">
>    <OGRVRTLayer name="2730_RIVER_LINE_2006_06">
> <SrcDataSource>2730/2730_RIVER_LINE_2006_06.shp</SrcDataSource>
>    </OGRVRTLayer>
>    <OGRVRTLayer name="2731_RIVER_LINE_2006_04">
> <SrcDataSource>2731/2731_RIVER_LINE_2006_04.shp</SrcDataSource>
>    </OGRVRTLayer>
>    <OGRVRTLayer name="2732_RIVER_LINE_2006_04">
> <SrcDataSource>2732/2732_RIVER_LINE_2006_04.shp</SrcDataSource>
>    </OGRVRTLayer>
>    </OGRVRTUnionLayer>
> </OGRVRTDataSource>
> Regards,
> Zoltan
http://www.spatialys.com
