[Qgis-developer] QEP/RFC sqlite virtual tables
Matthias Kuhn matthias.kuhn at gmx.ch
Tue Oct 28 01:46:49 PDT 2014
Hi Hugo,
Sorry for my slow response, I was quite busy the last days.
I'll try to explain a bit more what I have in mind.
For example there is the new expression function "getFeature()" which is
an ad-hoc replacement for a join. I have been told that the performance
for rendering is not very good, I assume this is caused by a lot of
requests performed in the background. It would be great to be able to
join this on the server side.
I would be very happy to see more of this introduced. For example I
could well imagine a new Expression (Syntax just made up, that can still
be designed in a more appropriate way)
   avg( c.population ) { LEFT JOIN cities c ON c.country_code =
$thistable.code }
This should then be locally evaluated (for shapefiles et al) but
forwarded to the server for database services (postgres and the like).
Now, as we have different backends and their syntax does not always
match (most do standard sql, but there are extensions, think of ST_* in
postgis, SDO_* in oracle spatial etc, and there is no guarantee, that a
dataprovider supports standard SQL) we need an abstraction layer and
cannot just assume that every dataprovider will understand the same thing.
I am planning to implement this abstraction layer for ordinary
expressions in the near future. And I would be very happy to see that
there is a way to extend this with aggregate functions. This will all
require a fallback level (if the server does not support a given
functionality, for shapefiles, to be sure that the result is the very
same regardless of server function implementation details...). We
already have this for ordinary expressions as we can just use the
QgsExpression implementation.
I can only repeat, that I will be more than happy to see this fallback
level implemented by means of sqlite virtual tables. But in my humble
opinion it would be very unfortunate if there would be no way to
optimize this tomorrow or the day after tomorrow. That's why I am asking
if sqlite developers are open to collaborate because if the will to
collaborate there is missing we will end up having to reimplement this
functionality.
I totally agree with your statement "A general cross-database SQL
optimizer would need lots of work (in QGIS and/or SQLite) and may come
later (if really needed).", but would append "and will require either a
re-implementation in QGIS, ending up in duplicated functionality"
(that's what Régis was worried about in the original mail) "or will need
the possibility to get deeper access to sqlite's internal data
structures or callbacks to optimize where required. This will require
cooperation from SQLite developer's side or forking sqlite.".
Best regards,
Matthias
Please help taking QGIS to the next level of quality. Before November 15 !
http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-automated-testing
