[Qgis-developer] Lizmap edit layer
Salvatore Larosa lrssvtml at gmail.com
Sat Sep 20 02:43:20 PDT 2014
On Sat, Sep 20, 2014 at 11:06 AM, Mira Maric <mmmxxxm at gmail.com> wrote:
> Hi. Same thing is when I save table in public schema or other schema.
> When I run:
> SELECT type FROM geometry_columns WHERE f_table_name = 'bus_stops' AND
> f_table_schema = 'topology'
> I get
> Type character varying (30)
> POINT
that is ok, and which QGIS and LizMapWC versions?
Could you provide the name of the geometry column in bus_stops table?
I don't see the geometry column name either in ST_AsText or
ST_Trasform, so it raises to
syntax error when you are editing the bus_stops table from the web client.
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
