[Qgis-developer] Problem with Qgis c++ plugin
Nejia nejia at spaceyes.fr
Mon Sep 22 00:42:26 PDT 2014
Building plugins with the libraries shipped with qgis-devl package resolve
my problem, previously I built plugins using libraries of Qgis that I built
from sources <https://github.com/qgis/QGIS/tree/release-2_4>  with Microsoft
Visual Studio as described here
<http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/I
NSTALL.html#toc14> .
BR
Nejia
-----Message d'origine-----
De : qgis-developer-bounces at lists.osgeo.org
[mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Jürgen E.
Fischer
Envoyé : vendredi 19 septembre 2014 18:27
À : qgis-developer at lists.osgeo.org
Objet : Re: [Qgis-developer] Problem with Qgis c++ plugin
Hi Hartmut,
On Thu, 18. Sep 2014 at 01:10:50 -0700, tschaun wrote:
> I have the same problem, and have had it for some time. I previously
> reported it for 2.2. My previous post received a response from Jürgen
> who said he had never seen this problem. This is not surprising as
> core developers build the application and plugins in one go, whereas
> this problem only crops up when a
> C++ plugin is deployed into a QGIS installation other than the one it
> C++ was
> built with.
Did you build you plugin with the libraries shipped with QGIS (ie. in the
OSGeo4W qgis-dev package for master or qgis-devel for the released version)?
That's what I do.   I don't build external (ie. non-core) plugins and qgis
in
one go either.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
