[Qgis-developer] Processing causes major slowness at QGIS startup
Victor Olaya volayaf at gmail.com
Wed Sep 24 02:10:36 PDT 2014
Luca, I just followed your advice and moved the Processing.initialize()
call to initGUI().
I did not test, however, to check that startup time has improved. The
change is already in master, so you can test it.
Let me know if you have more suggestions
Thanks!
2014-09-19 14:02 GMT+02:00 Luca Manganelli <luca76 at gmail.com>:
> On Thu, Aug 28, 2014 at 5:31 PM, Victor Olaya <volayaf at gmail.com> wrote:
> > I am away until Sept 5th, but will work on that once i am back. Didn't
> know
> > about the init() and initGUI() separation, so thanks for the info.
> > A large part of the time it takes to start Processing is probably spent
> in
> > reading the description files for SAGA, GRASS and OTB algorithms, so i
> will
> > try to find a way of making that faster, or avoiding it if not needed at
> > first
> Hi Victor, have you found the cause problem? It would be nice if you
> can fix fix this startup slowdown before 2.6 version (dated at end of
> octoer).
> Thank you!
> Luca
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140924/e8ec7762/attachment.html>
