[Qgis-developer] qgis-web-client: module wsgi
Enzo Cocca enzo.ccc at gmail.com
Thu Apr 23 13:52:23 PDT 2015
I have solved!! YUPPYYYYYYYYYYYYYYYYYY
I writed the code  #mod_wsgi to apache config
into virtual host and so the mod_wsgi not worked
<VirtualHost *:80>
  ServerAdmin webmaster at localhost
  # Add an entry to your /etc/hosts file for qgis-web-client.localhost e.g.
  # 127.0.0.1 qgis-web-client.localhost
  ServerName localhost
  WSGIDaemonProcess gis processes=5 threads=15 display-name=%{GROUP}
  WSGIScriptAlias /wsgi/ /home/www/wsgi/
  WSGIScriptAliasMatch ^/wsgi/([^/]+) /home/www/wsgi/$1.wsgi
</VirtualHost>
Than I have try to write out virtual host (
 the first three lines) and enjoi!!
thanks for suggestions and help
Enzo
2015-04-24 0:22 GMT+04:00 Andreas Neumann <a.neumann at carto.net>:
>  Hi Enzo,
> This has nothing to do with QGIS. Please google something like "wsgi
> Apache setup" - e.g.
> https://code.google.com/p/modwsgi/wiki/QuickConfigurationGuide and make
> sure you can handle your Apache setup. Make sure you can run the hello
> world example listed in the modwsgi documentation.
> Then you can continue to come back with QGIS server questions.
> Andreas
> On 23.04.2015 19:33, Enzo Cocca wrote:
> Hi Bernard,
> I have followed
> If I put the wsgi folder in /usr/lib/cgi-bin/ and set apache config like
>   WSGIScriptAlias /wsgi/ /usr/lib/cgi-bin/wsgi/
>   WSGIScriptAliasMatch ^/wsgi/([^/]+) /usr/lib/cgi-bin/wsgi/$1.wsgi
>  I have internal error 500. You  I'm not understand  again
> sorry
> E
> 2015-04-23 9:42 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de>:
>> Hi Enzo,
>> do not put it into html (see section 6 of the QWC documentation) maybe in
>> that location it is not run as a script but accessed by the browser as any
>> other html file (remember: I am no expert on this).
>> Basically you should not see the file at all in the browser, if an error
>> occurs it should be in Apache's error log.
>> Be sure ther is no space as the first character of the first line (as was
>> suggested before).
>> Bernhard
>> Am 22.04.2015 22:15, schrieb Enzo Cocca:
>>> I continue to have the problem with mod_wsgi module. I not
>>> understand....  I have set the  apache config like suggest bernhard and
>>> I have put my wsgi folder in /var/www/html but I continue to have the
>>> error:
>>> illegal charcther #! /usr/bin/python
>>> I have reinstalled libapache2-mod-wsgi, but nothing
>>> I use ubuntu server 14.04 apache 2.4 python 2.7
>>> Thanks at all for help
>>> E
>>> 2015-04-22 16:32 GMT+04:00 Bernhard Ströbl <bernhard.stroebl at jena.de
>>>  <mailto:bernhard.stroebl at jena.de>>:
>>>     Hi Enzo,
>>>     as I wrote in a previous post: Make sure the user running the apache
>>>     process has access to the wsgi directory. Try putting the wsgi in
>>>     /home/somthing e.g. in /var/www/wsgi
>>>     Bernhard
>>>     Am 22.04.2015 14:07, schrieb Enzo Cocca:
>>>         Hi all,
>>>         I looked for a solution but without results.
>>>         After set the default file in apache like that:
>>>         <VirtualHost *:80>
>>>             ServerName <localhost>
>>>             DocumentRoot /var/www/html/wms/site
>>>             <Directory />
>>>               Options FollowSymLinks
>>>               AllowOverride None
>>>             </Directory>
>>>             <Directory /var/www/html/wms/site/>
>>>               DirectoryIndex index.php index.html
>>>               Options Indexes FollowSymLinks MultiViews
>>>               AllowOverride None
>>>               Order allow,deny
>>>               allow from all
>>>               Require all granted
>>>             </Directory>
>>>             ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
>>>             <Directory "/usr/lib/cgi-bin/">
>>>               AllowOverride None
>>>               Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
>>>               Order allow,deny
>>>               Allow from all
>>>               Require all granted
>>>               SetEnv QGIS_LOG_FILE /tmp/qgislog.txt
>>>             </Directory>
>>>             RewriteEngine On
>>>             RewriteRule ^/cgi-bin/.*$ - [F]
>>>             RewriteRule ^/wms/(.+)$
>>>         /cgi-bin/qgis_mapserv.fcgi?map=/var/www/html/wms/projects/$1.qgs
>>>         [QSA,PT]
>>>             RewriteRule ^/maps/?$ / [PT]
>>>             RewriteRule ^/maps/([^\.]+)$ /qgiswebclient.html [PT]
>>>             RewriteRule ^/maps/(.*) /$1 [PT]
>>>             #mod_wsgi
>>>             #LoadModule wsgi_module /usr/lib/apache2/modules/mod_wsgi.so
>>>             <Directory "/home/www/wsgi/">
>>>                   Order allow,deny
>>>                   Allow from all
>>>             </Directory>
>>>             ErrorLog ${APACHE_LOG_DIR}/qgis-web-client-error.log
>>>             CustomLog ${APACHE_LOG_DIR}/qgis-web-client-access.log
>>> combined
>>>         </VirtualHost>
>>>         and the GlobaOptions.js like that;
>>>         //URL for custom search scriptsnull; //
>>>         var searchBoxQueryURL =  "/wsgi/search.wsgi?query="; // null:
>>>         var searchBoxGetGeomURL =  "/wsgi/getSearchGeom.wsgi";//null; //
>>>         The status is:
>>>         NetworkError: 404 Not Found -
>>> http://localhost/wsgi/search.wsgi?query=&searchtables=&query=qqq&cb=stcCallback1001
>>>         So it not found the path of wsgi, but in default config I have
>>>         give the
>>>         alias
>>>         any idea?
>>>         E
>>>     __________ Information from ESET Mail Security, version of virus
>>>     signature database 11515 (20150422) __________
>>>     The message was checked by ESET Mail Security.
>>>     http://www.eset.com
>>>     _______________________________________________
>>>     Qgis-developer mailing list
>>>      Qgis-developer at lists.osgeo.org <mailto:
>>> Qgis-developer at lists.osgeo.org>
>>>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> signature database 11519 (20150423) __________
>> http://www.eset.com
>   Enzo Cocca PhD
> in "Science and Technology for Archaeology and Cultural Heritage"
> mail: enzo.ccc at gmail.com
> cell: +393495087014
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
Enzo Cocca PhD
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150424/a3203646/attachment-0001.html>
