[Qgis-developer] Implementation of Python bindings in QGIS
Alessandro Pasotti apasotti at gmail.com
Sat Aug 1 01:10:40 PDT 2015
2015-07-31 22:26 GMT+02:00 Rob Marjot <robmarjot at gmail.com>:
> Thank you Alessandro. Plainly pointing out the use of SIP means that the
> bindings are 100% generated, painlessly following any new developments in
> the c++ code base?
Painlessly? Unfortunately not.
Some manual code tweaking is often required, see here for examples:
https://github.com/qgis/QGIS/blob/master/python/core/qgsapplication.sip#L9
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150801/467d8666/attachment.html>
