[Qgis-developer] Compiling ui files with custom widgets creates wrong imports
Denis Rouzaud denis.rouzaud at gmail.com
Thu Aug 6 00:24:22 PDT 2015
You need to have qgis lib in your python path.
On windows, that would be C:\OSGeo4W\apps\qgis-dev\python\qgis
To check this, just do "from qgis.gui import *" in python. If you don't
have an error, then pyuic4 will work properly.
Best wishes,
Denis
On 08/05/2015 11:27 PM, Anita Graser wrote:
> Hi,
> There seems to be an issue with custom widgets in Python. For example
> this plugin bug: ImportError: No module named qgsfieldcombobox
> (https://github.com/informeren/qgis-cartogram/issues/2)
> Compiling with
> pyuic4 -o cartogram_dialog_base.py cartogram_dialog_base.ui
> results in
> from qgsfieldcombobox import QgsFieldComboBox
> while it should be
> from qgis.gui import QgsFieldComboBox
> Is there some way to fix this on our side?
> Best wishes,
> Anita
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/c2435d8a/attachment-0001.html>
