[Qgis-developer] QGIS 2.10.1 Pisa - Read CSV file problem
Jürgen E. Fischer jef at norbit.de
Thu Aug 6 03:02:48 PDT 2015
Hi Zoltan,
On Thu, 06. Aug 2015 at 08:04:19 +0200, Zoltan Szecsei wrote:
> Whilst I am not too perturbed because I can get around this issue, I
> figured it was my "civic" duty to raise it.
You can also use "Add Vector layer..." to load that csv (via OGR) and it'll
have the original field names (if they are quoted in the first line - like in
your example) and workaround that edge case.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150806/f1ab2336/attachment.pgp>
