[Qgis-developer] Building plugin for Print Composer
Vincent Mora vincent.mora at oslandia.com
Fri Aug 7 01:58:17 PDT 2015
Hi all,
I need to add graphs generated by a plugin to compositions. I'm
considering to develop a PluginComposerItem in the same spirit as
PluginLayers, adding/removing a button in the toolbar when the plugin is
registered/removed.
Is that what was needed in your cases, or was a more general approach
required (like the qgis plugin mechanism, being able to access the
interface) ?
V.
Le 22/06/2015 18:05, G. Allegri a écrit :
> The suggestion from John is exactly what we did too. And we also built
> a chart composer...
> It would be great to have the means to know what other teams are
> working to. It would save a lor of time and money and, probably, get
> better software from a shared effort ;)
> giovanni
> Il 22/giu/2015 19:31, "John Gitau" <gkahiu at gmail.com
> <mailto:gkahiu at gmail.com>> ha scritto:
>     Hi Jakob,
>     A workaround would be to have a plugin that creates a new composer
>     view object:
>     /custom_composer = self.iface.createNewComposer("My Composer")/
>     Then get a reference to the main window in the composer view:
>     /main_window = custom_composer.composerWindow()/
>     Then you can either add a new toolbar (and required actions) or
>     append an action to the main toolbar. Have a look at the
>     ComposerWrapper class for something similar we implemented for
>     designing charts in the
>     composer: https://gist.github.com/gkahiu/06a43a589f9441736397
>     Hope this is helpful.
>     Cheers,
>     John
>     On Mon, Jun 22, 2015 at 2:07 PM, G. Allegri <giohappy at gmail.com>
>     wrote:
>         You can act on it but you can't custom gui widgets to the
>         Composer interface.
>         I cannot check the code right know. I listen to a specific
>         (existing) composition opening but if I remember correctly you
>         can watch the Composer opening too.
>         Il 22/giu/2015 17:19, "Jakob Lanstorp" <jlanstorp at gmail.com>
>         ha scritto:
>             Hi Giovanni, thanks for the update. Another solution would
>             be to catch the
>             event when a user starts an existing print composer.
>             Cannot in doc for the
>             pyqgis API find anything for this. Anyone who know is one
>             can listens for a
>             print composer to startup by the user and act on it.
>             Jakob Lanstorp
>             View this message in context:
>             http://osgeo-org.1560.x6.nabble.com/Building-plugin-for-Print-Composer-tp5212187p5212221.html
>             Sent from the Quantum GIS - Developer mailing list archive
>             at Nabble.com.
>             _______________________________________________
>             Qgis-developer mailing list
>             Qgis-developer at lists.osgeo.org
>             http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150807/d2fe4b06/attachment.html>
