[Qgis-developer] Troubles with qwtpolar
Andreas Neumann a.neumann at carto.net
Sun Aug 16 09:01:51 PDT 2015
Thanks Bas - this seems to work.
Andreas
On 16.08.2015 17:39, Sebastiaan Couwenberg wrote:
> On 16-08-15 17:23, Andreas Neumann wrote:
>> I upgraded a laptop with Ubuntu 15.04 and I can't compile QGIS because
>> of qwtpolar. I tried with internal qwtpolar, but it complains that it is
>> not compatible with qwt6.1 and above (which seems to be the default in
>> Ubuntu 15.04). It also seems like Ubuntu 15.04 doesn't provide a package
>> for qwtpolar, so if I turn internal qwtpolar off it complains that it
>> can't find qwtpolar.
>> What do you recommend to do on Ubuntu 15.04?
> Using the -DWITH_QWTPOLAR=OFF CMake option should be sufficient to build
> QGIS with Qwt >= 6.1.
> The qwtpolar embedded copy needs to be updated to qwtpolar-1.1 for Qwt
>> = 6.1 support, see:
> http://hub.qgis.org/issues/13156
> Kind Regards,
> Bas
