[Qgis-developer] Troubles with qwtpolar
Matthias Kuhn matthias at opengis.ch
Sun Aug 16 11:29:26 PDT 2015
Short background:
History:
 * qwtpolar is used for showing the satellite map on the gps widget
 * ubuntu, debian (osgeo4w, mac I guess) don't ship qwtpolar packages
 * therefore qwtpolar source code is shipped with the qgis source code
 * the qwtpolar source code in the qgis repository is no longer
compatible with the latest qwt library
Options:
 * update the qwtpolar source code in the qgis repository
 * remove the satellite display (that's what's currently done when
qwtpolar is disabled)
 * re-implement the satellite display without unpackaged external
dependencies (I'd love to see somebody do that, e.g. a QML component
would be great)
Until then: make sure you have an old qwt library ready (qwt < 6.1),
have a system that ships a recent version of qwtpolar (e.g. Fedora) or
turn off WITH_QWTPOLAR.
Cheers,
Matthias
On 08/16/2015 08:11 PM, J.O. Williams wrote:
> Andreas,
> I would like to suggest that qwtpolar option be changed to OFF
> permanently and use the embedded copy exclusively.  I have had trouble
> with option a couple of times and have tried to install the qwtpolar
> library.  And have wasted a hour each time trying to reinstall before
> I remember the change needed. The library  is no longer being
> maintained and is probably dead code.
> I also build using Ubuntu 14.04 LTS.
> TIA
> J.O. Williams
> On 08/16/2015 10:01 AM, Andreas Neumann wrote:
>> Thanks Bas - this seems to work.
>> Andreas
>> On 16.08.2015 17:39, Sebastiaan Couwenberg wrote:
>>> On 16-08-15 17:23, Andreas Neumann wrote:
>>>> I upgraded a laptop with Ubuntu 15.04 and I can't compile QGIS because
>>>> of qwtpolar. I tried with internal qwtpolar, but it complains that
>>>> it is
>>>> not compatible with qwt6.1 and above (which seems to be the default in
>>>> Ubuntu 15.04). It also seems like Ubuntu 15.04 doesn't provide a
>>>> package
>>>> for qwtpolar, so if I turn internal qwtpolar off it complains that it
>>>> can't find qwtpolar.
>>>> What do you recommend to do on Ubuntu 15.04?
>>> Using the -DWITH_QWTPOLAR=OFF CMake option should be sufficient to
>>> build
>>> QGIS with Qwt >= 6.1.
>>> The qwtpolar embedded copy needs to be updated to qwtpolar-1.1 for Qwt
>>>> = 6.1 support, see:
>>> http://hub.qgis.org/issues/13156
>>> Kind Regards,
>>> Bas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150816/f0a99ce8/attachment.pgp>
