[Qgis-developer] QGIS GRASS plugin - modules upgrade
Vaclav Petras wenzeslaus at gmail.com
Tue Aug 18 12:39:43 PDT 2015
On Tue, Aug 18, 2015 at 8:09 AM, Radim Blazek <radim.blazek at gmail.com>
wrote:
> On Tue, Aug 18, 2015 at 9:14 AM, Martin Landa <landa.martin at gmail.com>
wrote:
> > Hi,
> > 2015-08-18 9:11 GMT+02:00 Radim Blazek <radim.blazek at gmail.com>:
> >> BTW, as Markus Neteler pointed out, there is a list differences
> >> between GRASS 6 and 7:
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Replacedandremovedmodules
> >>   https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedmodules
> >>   https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Optionschanges
> >> and a table used by the commands to advertise new parameters in case
> >> the user used the old style:
https://svn.osgeo.org/grass/grass/branches/releasebranch_7_0/lib/gis/renamed_options
> >> If you upgrade a module definition in QGIS, please update also its
status on
> >> https://grasswiki.osgeo.org/wiki/GRASS-QGIS_relevant_module_list
> > I wonder why UI is not generated on the fly or during compilation? To
> > maintain manually UI in QGIS is complicated and the result will be
> > always out-of-date. Just 2 my cents, Martin
> UI is generated on the fly when a module UI is opened. It is using
> options description printed by GRASS module (--interface-description)
> combined with options definition for the module in QGIS (.qgm file).
> The additional options definition in QGIS is mainly for two purposes:
> 1) limit number of options not to frighten users, some GRASS modules
> are also represented as multiple items with predefined options
Hi Radim and Martin,
I guess that one of the reasons for QGIS interface for GRASS. Anyway, is
there a option of not using .qgm file and using --interface-description
only? This would not only enable some of the hidden features but more
importantly, it would enable to use of modules from GRASS GIS Addons
repository.
> 2) define relations between options (e.g. type or column option
> relation with input vector) or special options which has dedicated
> widget in UI (e.g. GDAL/OGR input).
This should be defined in GRASS GIS. If it is missing in GRASS or in the
--interface-description then it is a bug which should be solved.
Here are examples of guidependency "option attribute":
https://trac.osgeo.org/grass/browser/grass/trunk/vector/v.distance/main.c#L222
https://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.what.vect/v.what.vect.py#L15
> It was surely difficult to keep options in sync with GRASS modules,
> but with the new debugging tool (in master), it is possible to check
> all options/modules with just one click.
This sounds really good.
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150818/1707a2ad/attachment.html>
