[Qgis-developer] Processing Modeler regression Unable to open datasource of intermediate results
Anita Graser anitagraser at gmx.at
Wed Aug 26 00:08:23 PDT 2015
There seems to be a regression between Processing 2.9 and 2.10 where 2.10
fails to run models because it cannot find the intermediate results it
produced in a previous step. The model runs perfectly in 2.9. Bellow you
can see an example to reproduce: just chain QGIS buffer and OGR dissolve
and it fails because it's looking for a file
:\Users\agraser\AppData\Local\Temp\processing\7f77fa47bcec4799818d1f5ea41cc8a9\OUTPUT.sh
(without C: and .sh instead of .shp)
Are you already aware of this or should I open a ticket.
Best wishes,
Anita
Algorithm dissolve starting...
Prepare algorithm: QGISFIXEDDISTANCEBUFFER_1
Running Fixed distance buffer [1/2]
Parameters: INPUT
=C:/Users/agraser/Downloads/qgis_sample_data/shapefiles/popp.shp, DISTANCE
=10000, SEGMENTS =5, DISSOLVE =True
Converting outputs
OK. Execution took 67.825 ms (1 outputs).
Prepare algorithm: GDALOGRDISSOLVEPOLYGONS_1
Running Dissolve polygons [2/2]
Parameters: INPUT_LAYER
=C:\Users\agraser\AppData\Local\Temp\processing\7f77fa47bcec4799818d1f5ea41cc8a9\OUTPUT.shp,
GEOMETRY =geometry, FIELD =TYPE, MULTI =False, FIELDS =False, COUNT =False,
AREA =False, STATS =False, STATSATT =TYPE, OPTIONS =
GDAL command:
cmd.exe /C ogr2ogr.exe
C:\Users\agraser\AppData\Local\Temp\processing\a44629a1c1f34bc4bf9d26ed974f2bb6\OUTPUTLAYERALGGDALOGRDISSOLVEPOLYGONS1.shp
OUTPUT -dialect sqlite -sql "SELECT ST_Union(geometry),TYPE FROM 'OUTPUT'
GROUP BY TYPE" -explodecollections
GDAL command output:
FAILURE:
`:\Users\agraser\AppData\Local\Temp\processing\7f77fa47bcec4799818d1f5ea41cc8a9\OUTPUT.sh'
with the following drivers.
-> ESRI Shapefile
-> MapInfo File
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> DGN
-> VRT
-> REC
-> Memory
-> BNA
-> CSV
-> NAS
-> GML
-> GPX
-> KML
-> GeoJSON
-> Interlis 1
-> Interlis 2
-> GMT
-> GPKG
-> SQLite
-> ODBC
-> WAsP
-> PGeo
-> MSSQLSpatial
-> OGDI
-> PostgreSQL
-> MySQL
-> PCIDSK
-> OpenFileGDB
-> XPlane
-> AVCBin
-> AVCE00
-> DXF
-> Geoconcept
-> GeoRSS
-> GPSTrackMaker
-> VFK
-> PGDump
-> OSM
-> GPSBabel
-> SUA
-> OpenAir
-> PDS
-> WFS
-> HTF
-> AeronavFAA
-> Geomedia
-> EDIGEO
-> GFT
-> GME
-> SVG
-> CouchDB
-> Idrisi
-> ARCGEN
-> SEGUKOOA
-> SEGY
-> XLS
-> ODS
-> XLSX
-> ElasticSearch
-> PDF
-> Walk
-> CartoDB
-> SXF
Converting outputs
OK. Execution took 0.125 ms (1 outputs).
Model processed ok. Executed 2 algorithms total
Converting outputs
Loading resulting layers
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150826/c9d40769/attachment-0001.html>
