[Qgis-developer] Processing framework - background processing
Alexander Bruy alexander.bruy at gmail.com
Thu Aug 27 06:40:10 PDT 2015
Hi Roberto,
again, there is no need to recompile.
All you need is to grab Processing code from the repository mentioned
by Marcus [0]. Not all code, only Processing. Look at the python/plugins
directory. Then put this code into your QGIS plugins directory. Usually this
is ~/.qgis2/python/plugins. That's all.
After this you can start QGIS as usual and test.
[0] https://github.com/mvcsantos/QGIS
2015-08-27 16:36 GMT+03:00 Geo DrinX <geodrinx at gmail.com>:
> Marcus,
> the ZIP you indicated is a complete QGIS source .
> Where  is your    Processing   installable on Windows ?   Do I need to
> recompile something ?
> I'm afraid I do not understand what I need to do.    Could you please
> explain me the singular steps ?
> Thank you
> Roberto
> 2015-08-27 14:12 GMT+02:00 Marcus Santos <mvcs at me.com>:
>> On 27 Aug 2015, at 11:48, Geo DrinX <geodrinx at gmail.com> wrote:
>> 2015-08-27 12:36 GMT+02:00 Marcus Santos <mvcs at me.com>:
>>> Oh sorry, this is the link:
>>> Look for the master branch, you'll find the code there.
>> OK.  I will unpack the ZIP under my:
>> c:\Users\rrr\.qgis2\python\plugins\
>> correct ?
>> Exactly, you just need to put the processing plugin under the plugins
>> directory.
>> But, it do not conflict with the default installed
>> c:\PROGRA~1\QGISPI~1\apps\qgis\.\python\plugins\processing
>> Versione disponibile: 2.10.1 (in Repository plugin ufficiale QGIS)
>> Well, I’m not sure if it works the same way on Windows but I suppose it’s
>> the same.
>> Perhaps, your version will deactivate  the default version automatically,
>> or  need I to deactivate it manually, before to install your ?
>> I guess so.
>> Thank you for testing the new implementation.
>> I'm looking forward to hear about the multithreading behaviour on Windows
Alexander Bruy
