[Qgis-developer] QGIS 2.10.1 currently uninstallable on Debian sid?
Jürgen E. Fischer jef at norbit.de
Fri Aug 28 00:27:22 PDT 2015
Hi Bas,
On Fri, 28. Aug 2015 at 09:17:39 +0200, Sebastiaan Couwenberg wrote:
> On 28-08-15 09:04, Paolo Cavallini wrote:
> > the package requires liblwgeom-2.1.7, which is not available (I think
> > this should be replaced with 2.1.8). As a result, python-qgis cannot be
> > installed.
> > Should I open a ticket?
> With the ongoing GCC 5 transitions and the uninstallable build
> dependencies this causes, reporting the issue is not much use.
And it's already fixed[1]. But for the reasons you pointed out, the package
build doesn't complete.
Jürgen
[1] https://github.com/qgis/QGIS/commit/7de000d5c3e614bf4bc197261b6c30b15af4ec7b#diff-3a8967c9c7449446ddcdc76faa20bfafL359
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150828/e27571d8/attachment.pgp>
