[Qgis-developer] [Processing] error updating "Processing"
Luigi Pirelli luipir at gmail.com
Thu Dec 3 04:50:24 PST 2015
Hi Stefano
as stated in a message in italian qgis community, the problem is that
you hare three qgis version using the same .qgis2/ where conf and user
plugin are installed
so you have a unique Processing but different version available
compatible with the three qgis version
you should start every qgis pointing to a different QGIS cofiguration
with --configpath option in every QGIS.bat used by different version.
when you do, please self answer to your message in qgis-user list to
notify the solution
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 3 December 2015 at 12:38, skampus <skampus at gmail.com> wrote:
> Hi, I have posted this on User list, but maybe is better to ask here...
> i have some installation of qgis on my windows 8.
> I installed via osgeo4w:
> 2.8.4-2 (LTR dev)
> 2.12.1-1 (Lyon)
> 2.13.0-21 (dev)
> but there is a problem with the update processing.
> In fact, if I upgrade it to 2.12.2 from 2.10.99, a directory called
> "processing" is created in C:\ Users\ ... \. qgis2\python\ plugins folder
> and this error comes out:
> Couldn't load plugin 'processing'
> ImportError: cannot import name spatialite_utils
> Traceback (most recent call last):
>   File "C:/OSGeo4W/apps/qgis/./python\qgis\utils.py", line 281, in
> loadPlugin
>     __import__(packageName)
>   File "C:/OSGeo4W/apps/qgis/./python\qgis\utils.py", line 572, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "C:/Users/11186cs/.qgis2/python/plugins\processing\__init__.py", line
> 29, in
>     from processing.tools.general import *
>   File "C:/Users/11186cs/.qgis2/python/plugins\processing\tools\general.py",
> line 28, in
>     from processing.core.Processing import Processing
>   File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\Processing.py", line
> 40, in
>     from processing.core.GeoAlgorithm import GeoAlgorithm
>   File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\GeoAlgorithm.py",
> line 41, in
>     from processing.core.parameters import ParameterRaster, ParameterVector,
> ParameterMultipleInput, ParameterTable, Parameter
>   File
> "C:/OSGeo4W/apps/qgis/./python/plugins\processing\core\parameters.py", line
> 33, in
>     from processing.tools.vector import resolveFieldIndex, features
>   File "C:/Users/11186cs/.qgis2/python/plugins\processing\tools\vector.py",
> line 20, in
>     from processing.algs.qgis import spatialite_utils
> Python version: 2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit
> (Intel)]
> QGIS version: 2.12.1-Lyon Lyon, 16760fd
> As consequence of this installation in the property of plugin window i read:
> Processing
> Spatial data processing framework for QGIS
> 77 rating vote(s), 196142 downloads
> Category: Analysis
> More info: homepage   tracker   code_repository
> Author: Victor Olaya
> Installed version: 2.12.2 (in
> C:\Users\11186cs\.qgis2\python\plugins\processing)
> Available version: 2.12.2 (in Repository plugin ufficiale QGIS)
> Now, it no longer works neither processing nor any plugins associated
> (processing_workflow, and so on).
> The only solution is to delete the directory called "processing", but that
> processing is outdated.
> is this a bug?
> thanks a lot
> stefano
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Processing-error-updating-Processing-tp5239827.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
