[Qgis-developer] postgres getFeatures segfault in pyqgis not in console
Richard Duivenvoorde rdmailings at duif.net
Wed Feb 4 08:35:54 PST 2015
On 04-02-15 17:23, Martin Dobias wrote:
> Looks like QApplication instance was not created, so all places where
> events are needed will fail (e.g. for postgres there is a connection
> pool which releases connections after some time). Something like this
> should be added to the top:
> import sys
> app = QApplication(sys.argv)
Hi Martin,
Thanks for your answer.
the actual script I was testing was this one (which has this stuff):
http://pastebin.com/MWdMzmTW
I now managed to create a stacktrace myself via
gdb --args /usr/bin/python test2.py
you can see the full output here (on the bottom the bt)
http://pastebin.com/F8f5ZJAf
Regards,
Richard
