[Qgis-developer] Browser tab crashes QGIS
Martin Dobias wonder.sk at gmail.com
Mon Feb 9 00:32:59 PST 2015
Hi
I am unable to reproduce with 2.6.1 / master on ubuntu 14.04...
Where exactly do you click? (tree view or header? a particular item in tree
view?)
Is it necessary that the splash screen is still shown?
What do you mean with the "tab" - is it necessary that the browser dock
widget occupies the same are with another dock widget (e.g. Layers), thus
creating two tabs?
Any chance to get a backtrace from the crash?
Maybe a screenshot would help showing where do you click.
Cheers
Martin
On Mon, Feb 9, 2015 at 3:18 PM, Matteo Ghetta <matteo.ghetta at gmail.com>
wrote:
> Hi,
> I confirm the problem.
> You have to be very fast and click on the browser tab after launching qgis.
> If you wait a while it works without crashing.
> Cheers
> Matteo
> Il giorno 09/feb/2015 08.56, "Anita Graser" <anitagraser at gmx.at> ha
> scritto:
>> On Mon, Feb 9, 2015 at 8:30 AM, Paolo Cavallini <cavallini at faunalia.it>
>> wrote:
>>> Il 09/02/2015 05:26, Alex Mandel ha scritto:
>>> > Not sure if anyone else has noticed this.
>>> > QGIS 2.6.x on Ubuntu 14.04
>>> > If you click the Browser tab as your 1st click inside a fresh run of
>>> > QGIS it crashes. Click anything else and then Browser and it's fine.
>>> > I've gotten it to work on several machines.
>>> > I'm not sure it's in master, but someone should probably check.
>>> Hi Alex,
>>> confirmed, I had this issue several times, but I never took the time to
>>> investivate if fully, as I believed it was a local issue.
>>> Thanks for raising it.
>>> All the best.
>> Hi,
>> Where exactly should it crash? I've tried clicking on the tab and inside
>> the dock but no crashes ...
>> QGIS 2.6.1 (ubuntugis-unstable) on Ubuntu 14.04
>> Best wishes,
>> Anita
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150209/52cd997b/attachment.html>
