[Qgis-developer] Error in new Metasearch
Tom Kralidis tomkralidis at gmail.com
Sun Jan 4 06:10:43 PST 2015
Thanks Richard.
Given that MetaSearch is now officially in QGIS core, we probably need
to cut an out of band release (0.3.3) to plugins.qgis.org, which is
built from QGIS core (0.3.2 is built from outside QGIS core).
On Mon, Dec 29, 2014 at 6:49 AM, Richard Duivenvoorde
<rdmailings at duif.net> wrote:
> On 29-12-14 10:29, Richard Duivenvoorde wrote:
>> On 29-12-14 10:09, Paolo Cavallini wrote:
>>> Il 26/12/2014 16:15, Tom Kralidis ha scritto:
>>>> Hi Paolo: master works for me.  Can you provide a usecase/workflow
>>>> I can try to reproduce?
>>> Hi Tom,
>>> just tested again: searching for "land", global extent, on all default
>>> servers returns no results (sometimes a timeout, sometimes an error
>>> 'NoneType' object has no attribute 'find' (for UNEP), sometimes just
>>> blank.
>>> Also "province" (a valid keyword, I believe) for the two Italian
>>> servers returns nothing.
>>> Can't see anything on the log.
>> Hi Paolo,
>> with me it is also working fine. The plugin manager shows me:
>> Installed version: 0.3.2 (in /home/richard/.qgis2/python/plugins/MetaSearch)
>> But I'm on Linux here...
> Ok, some further investigation:
> - an excisting osgeo4w install, after upgrading the dev version,
> starting in english is ok
> - switching to italian gives you the old 'not all arguments converted'
> error... (Python path at that moment is FIRST giving the .qgis2 and then
> the core plugins path)
> - removing the plugin from the .qgis2 directory then ends up in a
> jinja2-not found error
> - doing a full clean install of osgeo4w installation
> - english again ok
> - italian again the same error
> - removing the plugin from the qgis2 directory (both places state that
> they have 0.3.2 version??)
> - italian WORKING !!!
> - reinstalling the plugin from plugins.qgis.org (both stating 0.3.2):
> problem is back again.
> So though I cannot confirm Paolo's problem, I can get a working italian
> version, BUT it looks like the version 0.3.2 on the plugin site is
> another version then the 0.3.2 version that is part of core?
> Regards,
> Richard
