[Qgis-developer] cannot compile qgis on opensuse 13.2 (64 bit) **newbie** **Fixed
Otto Dassau dassau at gbd-consult.de
Wed Jan 14 01:25:28 PST 2015
Am Wed, 14 Jan 2015 20:19:47 +1100
schrieb h <hdixon at bigpond.net.au>:
> On Sun, 11 Jan 2015 17:34:57 +1100
> h <hdixon at bigpond.net.au> wrote:
> > Hi,
> > I have previously done compiles of qgis by following instructions
> > similar to
> > https://raw.githubusercontent.com/qgis/QGIS/master/INSTALL, with only
> > minor trouble. I now have a new PC and new version opensuse - and I
> > cannot work out why it is not compiling.
> > The error I get is:
> > make[2]: *** No rule to make target
> > '/usr/lib/postgresql93/lib64/libpq.so', needed by
> > 'output/lib/qgis/plugins/libpostgresprovider.so'.  Stop.
> > CMakeFiles/Makefile2:1978: recipe for target
> > 'src/providers/postgres/CMakeFiles/postgresprovider.dir/all' failed
> > make[1]: ***
> > [src/providers/postgres/CMakeFiles/postgresprovider.dir/all] Error 2
> > My understanding is that libpq.so is part of postgres, and should not
> > need to be built.
> > In my install libpg.so is in /usr/lib64.
> > I have tried a number of different values for the POSTGRESQL_PREFIX
> > value in ccmake, without any success.
> > Could someone please give me an idea how to get libpostgresprovider.so
> > to build.
> > I do have an active postgres database which I have used to provide
> > data to an installed version of qgis.
> > With thanks,
> > H
> > ____________________________________________
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> A did a fetch on qgis, and had an update of my distro and now have a
> completed build.
> H
the POSTGRES_LIBRARY path to libpq.so is /usr/lib64/libpq.so. You need to
adapt that.
Regards
Otto
