[Qgis-developer] problem with GROUP BY in `Execute SQL` Processing
Jürgen E. Fischer jef at norbit.de
Tue Jan 20 01:40:05 PST 2015
Hi Matteo,
On Tue, 20. Jan 2015 at 09:47:50 +0100, Matteo Ghetta wrote:
> yes, the column is ID.
Meaning that ID is the only column in au?  Did you try to use ID instead of *?
> On Fri, 16. Jan 2015 at 10:48:16 +0100, Matteo Ghetta wrote:
> > GDAL execution console output
> > ERROR 1: SQL Expression Parsing Error: syntax error
> Maybe GROUP BY function is not supported in Processing yet?
Well, I don't really know processing, but it looks more like an error from OGR.
Anyway, my observation was just about the SQL.  You usually don't use * with
GROUP BY, because you can only select columns that appear in the GROUP BY and
can only use other in aggregate functions (min, max, sum...).
Maybe you can use: select distinct id from au
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150120/4a9f64bd/attachment.pgp>
