[Qgis-developer] Installing 2.4 on debian
Tim Sutton tim at kartoza.com
Sun Jan 25 06:02:13 PST 2015
Hi All
Can anyone help withthe correct procedure for installing older versions on
debian Jessie from package?
root at 6b2c81edac61:/# apt-get install qgis=2.4.0-1+b1
qgis-providers=2.4.0-1+b1 qgis-common=2.4.0-1
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 qgis-providers : Depends: qgis-providers-common (= 2.4.0-1) but
2.6.1.1+jessie1 is to be installed
W: Ignoring Provides line with DepCompareOp for package
php-psr-log-implementation
W: You may want to run apt-get update to correct these problems
E: Unable to correct problems, you have held broken packages.
It would be nice to have the historical versions available for install
given that with various things changing over releases, it is nice to be
able to replicate a known good configuration for a given software
architecture.
Regards
Tim
Tim Sutton
Visit http://kartoza.com to find out about open source:
 * Desktop GIS programming services
 * Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150125/9784a8f7/attachment.html>
