[Qgis-developer] SAGA kernel missing CRS?
Paolo Cavallini cavallini at faunalia.it
Sat Jul 11 02:08:06 PDT 2015
Il 10/07/2015 19:47, Victor Olaya ha scritto:
> hmmm, really weird. Can you check that the prj file that is created
> has the same content as the one of the input file?
> it should not be different on linux or windows, since it has nothing
> to do with saga actually. It is just rewritting the prj file, which
> should be the same in both OSs
this is the prj:
PROJCS["OSGB 1936 / British National Grid",GEOGCS["OSGB
1936",DATUM["OSGB_1936",SPHEROID["Airy
1830",6377563.396,299.3249646,AUTHORITY["EPSG","7001"]],TOWGS84[446.448,-125.157,542.06,0.15,0.247,0.842,-20.489],AUTHORITY["EPSG","6277"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4277"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",49],PARAMETER["central_meridian",-2],PARAMETER["scale_factor",0.9996012717],PARAMETER["false_easting",400000],PARAMETER["false_northing",-100000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","27700"]]
so it looks like a qpj, I think this is why it is not recognized.
> Anyway, good idea, we will publish a new version and let people test it
please do, thanks!
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
