[Qgis-developer] Fwd: Re: Processing algorithm's groups and names translation.
Victor Olaya volayaf at gmail.com
Wed Jul 15 07:54:59 PDT 2015
No need to do that
There is a name property for algorithms (used by the toolbox, not the
cmd line), and then there is the getCommandLineName() method, (which
is used by the command line). The problem here is that, by default,
the getCommandLineName method returns a name that is derived from the
alg name. It is easy to fix that, just override that method for all
algorithms. The problem is that "all" algorithms means hundreds of
them...
It's something that should have been done from the beginning, but I
just assumed that it was a good idea to rely on the base
implementation which uses the human-readable name for the cmd line
name, so there was no need to implement that method ofr every
algorithm, saving some work. Lazy me...
So, in short, the code actually supports what you propose...but
algorithms do not use it,
Let me know if you have questions
2015-07-15 16:01 GMT+02:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
> Thanks for your reponse,
> This is functionnal but seems difficult to maintain.
> How to verify that every algorithm is translated in each language ?
> Why don't add in each algorithm a "title" property
>     self.name = '...'             # used by command line
>     self.title = self.tr('...')     # used by toolbox
> eventually with a fallback on self.name for compatibility with
> algorithms from external plugins.
> Like this we could use the normal workflow with transifex.
> Does the groups have another use than toobox item text ? can we replace :
>     self.group = '...'
> by
>     self.group = self.tr('...')
> Arnaud
> Le 15/07/2015 12:26, Victor Olaya a écrit :
>> Arnaud
>> I added a mechanism for defining alternative names for algorithms.
>> This allows to provide more informative names than the original ones,
>> without having to break the cmd interface.
>> The name replacements are stored in this file:
>> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/gui/algnames.txt
>> If the algorithm is listed there, the alternative name is use.
>> Otherwise, the original name is used.
>> Maybe we could have several files like that (algnames_fr.txt,
>> algnames_es.txt, etc), and just use the one corresponding to the
>> current language. That would be a very easy solution to implement and
>> very practical for all translators. It's differnet from how
>> translation is done now, but I think it will be better for Processing,
>> to be able to rename algorithms without changing their commandline
>> name
>> Let me know what you think about this
>> Cheers
>> 2015-07-15 11:16 GMT+02:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
>>> Hi,
>>> In processing algorithms, parameters names are translatable (and
>>> completely
>>> translated in french),
>>> but algorithm names and groups couldn't be translated because processing
>>> commandline interface use them in english.
>>> On the other side, it would be good for users to get algorithm names
>>> translated inside toolbox.
>>> Has someone begin to work on this or an idea about how to get names
>>> Maybe we could help on this ?
>>> Best regards
>>> Arnaud
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
