[Qgis-developer] Data-defined symbol size is not backwards compatible to 2.8.2
Anita Graser anitagraser at gmx.at
Mon Jun 1 12:03:01 PDT 2015
Hi Régis,
On Mon, Jun 1, 2015 at 8:05 PM, Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr> wrote:
> - offer an assistant on size varying common expression. You will find it at
> the bottom of the drop down widget. It computes max value from field or
> expression and allows normal user to do what other GIS do.
> - That assistant offer legend previsualisation, and generates a legend for
> map and composer.
​I just tested the assistant for the first time and it's just great! Will
definitely test some more and report back.
Thanks for your work on this!​
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150601/00eee27d/attachment.html>
