[Qgis-developer] error during compiling [libproj.so]
Matteo Ghetta matteo.ghetta at gmail.com
Sat Jun 6 02:45:44 PDT 2015
Ok i ll try it and let you know!
Thanks!!
Il giorno 06/giu/2015 11.42, "Werner Macho" <werner.macho at gmail.com> ha
scritto:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi!
> No need to delete the cloned QGIS repository - just "clean" the build
> directory ..
> (or remove the build directory and create it again)
> That should be enough to help you getting started again...
> regards
> Werner
> On 06/06/15 11:39, Matteo Ghetta wrote:
> > Hi Sebastiaan, thanks! So, in simple words, I can delete the QGIS
> > git cloned directory, re-clone it, create a new build directory and
> > run a new ccmake. Right?!
> > Cheers
> > Matteo
> > 2015-06-06 11:33 GMT+02:00 Sebastiaan Couwenberg
> > <sebastic at xs4all.nl <mailto:sebastic at xs4all.nl>>:
> > On 06/06/2015 11:30 AM, Matteo Ghetta wrote:
> >> So what exacly should I do? Should I re-run ccmake in order to
> >> have another list of all the paths?
> > Throw away your old build directory, recreate it and run `cmake
> > ..` from inside it.
> > Kind Regards,
> > Bas
> > _______________________________________________ Qgis-developer
> > mailing list Qgis-developer at lists.osgeo.org
> > <mailto:Qgis-developer at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2
> iEYEARECAAYFAlVywGQACgkQDAH1YiCxBgmFEQCfe9yilTx1/OrAk74T/gRI6mj3
> 8KIAn3c0qFmf3o6OW9mA/kGjMBwaVf5F
> =WPOX
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150606/470b08c4/attachment.html>
