[Qgis-developer] error during compiling [libproj.so]
Matteo Ghetta matteo.ghetta at gmail.com
Sun Jun 7 14:08:42 PDT 2015
HI Werner,
thanks for the infos!
Cheers
Matteo
2015-06-07 16:39 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Matteo,
> You can leave QWT-Polar on.
> There are two different switches.
> WITH_QWT_POLAR and
> WITH_INTERNAL_QWT_POLAR
> If you set both of them to ON QGIS takes the included qwt libraries
> for compilation.
> There was a discussion at some point the remove internal qwt libraries
> from the source but as for e.g. debian has no qwt package it is still
> necessary to include it.
> Hope this helps in compiling with qwt support.
> kind regards
> Werner
> On 07/06/15 15:30, Matteo Ghetta wrote:
> > Hi all, just to let you know that I had to set WITH_POLAR to OFF
> > and then the compilation rans without problems.
> > Thanks to all!
> > Matteo
> > 2015-06-07 12:42 GMT+02:00 Matteo Ghetta <matteo.ghetta at gmail.com
> > <mailto:matteo.ghetta at gmail.com>>:
> > Hi I have tried to compile, but some problems:
> > * QT_Polar libraries.. I set them to OFF as suggsted in a post
> > (else, the compilation would not start), but, during the
> > compilation I get this error:
> > In file included from
> > /home/ma7730/lavori/QGIS-master/src/app/qgisapp.cpp:139:0:
> > /home/ma7730/lavori/QGIS-master/src/app/gps/qgsgpsinformationwidget.h:
> 27:28:
> fatal error: qwt_polar_plot.h: No such file or directory
> > #include <qwt_polar_plot.h> ^ compilation terminated.
> > src/app/CMakeFiles/qgis.dir/build.make:1346: recipe for target
> > 'src/app/CMakeFiles/qgis.dir/qgisapp.cpp.o' failed make[2]: ***
> > [src/app/CMakeFiles/qgis.dir/qgisapp.cpp.o] Error 1
> > CMakeFiles/Makefile2:2410: recipe for target
> > 'src/app/CMakeFiles/qgis.dir/all' failed make[1]: ***
> > [src/app/CMakeFiles/qgis.dir/all] Error 2 Makefile:146: recipe for
> > target 'all' failed make: *** [all] Error 2
> > What can I do?
> > Thanks!
> > Matteo
> > 2015-06-06 11:41 GMT+02:00 Werner Macho <werner.macho at gmail.com
> > <mailto:werner.macho at gmail.com>>:
> > Hi!
> > No need to delete the cloned QGIS repository - just "clean" the
> > build directory ..
> > (or remove the build directory and create it again)
> > That should be enough to help you getting started again...
> > regards Werner
> > On 06/06/15 11:39, Matteo Ghetta wrote:
> >> Hi Sebastiaan, thanks! So, in simple words, I can delete the
> >> QGIS git cloned directory, re-clone it, create a new build
> >> directory and run a new ccmake. Right?!
> >> Cheers
> >> Matteo
> >> 2015-06-06 11:33 GMT+02:00 Sebastiaan Couwenberg
> >> <sebastic at xs4all.nl <mailto:sebastic at xs4all.nl>
> > <mailto:sebastic at xs4all.nl <mailto:sebastic at xs4all.nl>>>:
> >> On 06/06/2015 11:30 AM, Matteo Ghetta wrote:
> >>> So what exacly should I do? Should I re-run ccmake in order to
> >>> have another list of all the paths?
> >> Throw away your old build directory, recreate it and run `cmake
> >> ..` from inside it.
> >> Kind Regards,
> >> Bas
> >> _______________________________________________ Qgis-developer
> >> mailing list Qgis-developer at lists.osgeo.org
> > <mailto:Qgis-developer at lists.osgeo.org>
> > <mailto:Qgis-developer at lists.osgeo.org>>
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2
> iEYEARECAAYFAlV0V4gACgkQDAH1YiCxBgme/QCeMmJyEpKi7oWsXJppX6jVNP/K
> j30AnjR3CNGs1hVyJEcuPmICj1rrReOf
> =MdeO
> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150607/0f92ed20/attachment.html>
