[Qgis-developer] Processing log: not saved?
Victor Olaya volayaf at gmail.com
Sun Jun 7 22:02:42 PDT 2015
You still have the same output as before. Everything that was logged
into the Processing log is now in a "Processing" tab in the QGIS log.
The only thing left in the sepoarate Processing history are the
executed commands, since that is an interactive log (you can double
click on a history entry to re-run the alg) and that cannot be
implemented in the QGIS log
So, in short, you have the same info, just with a more coherent
structure for a core plugin, as it was mentioned before
Cheers
2015-06-07 23:37 GMT+02:00 Salvatore Larosa <lrssvtml at gmail.com>:
> Hi,
> On Sun, Jun 7, 2015 at 9:26 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> On Sun, Jun 7, 2015 at 7:51 PM, Paolo Cavallini <cavallini at faunalia.it>
>> wrote:
>>> Hi all,
>>> The recent changes in Processing solved a number of issues - in general
>>> I think it is now more polished and  usable.
>>> One thing I did not understand, however, is why the log has disappeared
>>> fro the History box. I may be missing something, but I believe having
>>> the possibility of going back to the outputs from several backends was a
>>> very useful feature.
>>> Is there a good reason not to put it back?
>> +1 for keeping the algorithm log.
> +1 how it is now, Processing is a core plugin and any core
> functionality should to show logs
> on the same place and I think the message logs widget of QGIS is the
> right place, imho.
> Best Regards,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> Qgis-developer mailing list
