[Qgis-developer] Bug in symbol size data-defined override
Vincent Mora vincent.mora at oslandia.com
Mon Jun 8 01:03:44 PDT 2015
On 05/06/2015 16:46, Alexandre Neto wrote:
> I'm still at 2.8.1 (I have no administrator permissions on this machine)
> Using data-defined override on a marker symbol does not seem to be working
> as it should. Comparing a layer where the marker size is set to 50 and
> another where we use 50 as an expression in data-defined override, they do
> not look the same, and I guess they should.
> Can anyone can confirm this, whether in 2.8 or in master?
Is the size-scale method set to Diameter ? If it's not the case (i.e.
scale method area), then a square root is applied if the size is defined
by an expression.
Cheers,
V.
> Thanks,
> Alexandre Neto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150608/0bcb90ff/attachment.html>
