[Qgis-developer] Problem compiling master can't find qwtpolar dir
Matteo Ghetta matteo.ghetta at gmail.com
Fri Jun 12 00:19:11 PDT 2015
HI Alexandre,
I had the same problem..
You can read this thread and you should be able to solve the problem:
http://lists.osgeo.org/pipermail/qgis-developer/2015-February/036602.html
Cheers
Matteo
2015-06-12 0:21 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com>:
> I used to be able to complile QGIS master in ubuntu 14.04 without any
> problems. Now I get some erros during ccmake ..
> It's not able to find qwtpolar nor qsci_sip_dir
>  QSCI_SIP_DIR                     QSCI_SIP_DIR-NOTFOUND
>  QWTPOLAR_INCLUDE_DIR             QWTPOLAR_INCLUDE_DIR-NOTFOUND
>  QWTPOLAR_LIBRARY                 QWTPOLAR_LIBRARY-NOTFOUND
> Can someone give me some hint to solve this?
> Thanks
> Alexandre Neto
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150612/657cf3cb/attachment.html>
