[Qgis-developer] Export atlas composition to a single PDF file
David Erill daviderill79 at gmail.com
Thu Jun 18 04:17:57 PDT 2015
DelazJ,
I've checked that code and it worked perfect!!
Thanks a lot
2015-06-18 12:29 GMT+02:00 DelazJ <delazj at gmail.com>:
> Hi,
> Following that discussion, I'm planning to release in a couple of weeks a
> new version of **Maps Printer** plugin that will export also atlases. I'm
> not sure the code I have in github is enough stable yet. Will give it a
> look soon.
> Meanwhile, You can see the code of **Surveying Calculation** plugin
> (bacth_plotting_dialog.py). It exposed a kind of python code of the needed
> function.
> 2015-06-18 12:02 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> On 18 June 2015 at 19:46, David Erill <daviderill79 at gmail.com> wrote:
>> > Hi devs!
>> > I need to Export atlas composition to a single PDF file.
>> > I have the same problem as the one exposed in this thread:
>> > http://lists.osgeo.org/pipermail/qgis-user/2014-August/028744.html
>> > Is that functionality already resolved through Python code?
>> No, unfortunately nothing's changed regarding that yet.
>> Nyall
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150618/a3a1777e/attachment.html>
