[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Alexandre Neto senhor.neto at gmail.com
Fri Jun 19 04:05:42 PDT 2015
Using the rule-based symbology with several rules and an ELSE expression.
If you, in map canvas legend, set a rule "layer" to invisible, all it's
features will be represented with the ELSE Symbol.
Not sure if this is the expected behaviour. I would expect that those
feature would simply became invisible.
Should I open a ticket?
Thanks,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/f3b562e1/attachment.html>
