[Qgis-developer] ELSE expression is used when other rules are set not visible - Feature or Bug?
Andreas Neumann
a.neumann at carto.net
Fri Jun 19 04:50:55 PDT 2015
In my opinion this is a bug. I agree that by switching off the rule
should not make the features fall into the ELSE rule. At least from a
usability point of view. Or we need to ELSE rules - a "TRUE ELSE" rule
that behaves like now and an "ELSE" rule that behaves like the users
expect it to behave.
Andreas
On 19.06.2015 13:36, Etienne Trimaille wrote:
> I've this kind of bug too.
> If you create a categorized symbology, apply the change and then
> switch to a ruled-based symbology (keeping the previous rules), you
> will see that the ELSE statement will draw features twice.
> Enable "show feature count" to check.
> I didn't check if there is a ticket for that.
> 2015-06-19 13:18 GMT+02:00 Alexandre Neto <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>>:
> Indeed Nathan,
> But do you thinks that is what you were expecting? when you turn
> the "layer" off?
> Alexandre
> On Fri, Jun 19, 2015 at 12:08 PM, Nathan Woodrow
> <madmanwoo at gmail.com <mailto:madmanwoo at gmail.com>> wrote:
> I would say they are getting skipped in the rule check so fall
> into the else rule.
> On Fri, 19 Jun 2015 9:05 pm Alexandre Neto
> <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> wrote:
> Using the rule-based symbology with several rules and an
> ELSE expression. If you, in map canvas legend, set a rule
> "layer" to invisible, all it's features will be
> represented with the ELSE Symbol.
> Not sure if this is the expected behaviour. I would expect
> that those feature would simply became invisible.
> Should I open a ticket?
> Thanks,
> Alexandre Neto
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150619/50937985/attachment.html>
